Smart Racing Anti-Roll Bars
I will be doing a complete suspension rebuild this winter and would like to use these. Are they still available? Any other suggestions on anti-roll bars?
Any input would be greatly appreciated. I will be using 22/29 sanders bars and Elephant Racing goodies as well.
Thanks,
Dean
Old 11-06-2011, 06:24 PM
toddu's Avatar
Tarett Engineering or Elephant Racing (same product for the most part).
Todd
'81 SC
Old 11-06-2011, 06:30 PM
Formerly known as Syzygy
Canada Kev's Avatar
I may be mistaken, but don't the drop links need brackets welded to the front control arms on both the Elephant and Tarett products? As I understand it, the Smart bars used a bolt on bracket. Small difference maybe, unless you don't have access to a welder...
Kevin
Old 11-06-2011, 07:02 PM
toddu's Avatar
Yes, welding u-tabs is necessary. But, it's very easy to grind the old tabs off and if you know someone that welds, that part takes 10 minutes.
Price difference is significant I think.
Todd
'81 SC
Old 11-06-2011, 07:23 PM
Canada Kev's Avatar
Todd
Which way? Elephant and Tarett are pretty close to each other. Was Smart higher or lower? For some reason, I seem to recall them being higher. But I can't remember what I ate for breakfast...
Kevin
Old 11-06-2011, 09:36 PM
Smart Racing gives you more adjustability through different bar diameters. That said, plenty of fast drivers and cars using the Elephant/Tarret bars.
Old 11-06-2011, 09:41 PM
