how to id tranny
OK i need to id the 915 the tranny in my 930, i know use the number by the tranny drain, they aren't there along with an oil drain but that another story, i'm more interested in tell if it is a mag or alum tranny, i would normally check the clutch actuator to see if it had a helper spring but it looks like an aftermarket arm, please help, is there any ribs i can could or see if a magnet stick??i am doing some mods to the motor and want to know if my tranny will hold up, thanks(as always)
tom
Old 03-25-2002, 11:59 AM
anybody ????????
Old 03-26-2002, 08:09 AM
Magnesium alloy will form a grey patina or coating from oxidation; it is also considerably softer than aluminum. Scape it a bit with a knife. Without the ID number it would be hard to determine the internal parts. Jim
Old 03-26-2002, 09:47 AM
Early_S_Man's Avatar
Porsche Crest
A little info about the year and model of the car would have helped!
If it is a factory Turbo, prior to '87, it would have the Type 930 transaxle, which were always aluminum, from the start!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-26-2002, 10:00 AM
MY car is a 76 Euro but has a 915 5 speed tranny, i am tryin to figure out which one it is, so i know if i will have to worry about hopping up the hp without worrying about the tran. I have the original 930 tranny but really like the 5 speed, it is geared perfectly for how i drive, thank guys
Old 03-26-2002, 09:31 PM
