jmshepard's Avatar
Carrera TPS or on/off Switch
Is this a throttle position sensor or just a switch?
Part number 944-606-113-01 on a 3.2 Carrera TB shown in red:
Thanks,
Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 05-23-2008, 09:22 AM
Will program for food
ghnat's Avatar
I believe just a switch. One is an idle switch and the other is WOT (Wide Open Throttle). But I'll let the experts chime in...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 05-23-2008, 09:28 AM
jmshepard's Avatar
Greg,
This is not what I wanted to read.
Thanks,
Jim S.
2009 Cayman
Old 05-23-2008, 09:35 AM
ghnat's Avatar
Jim,
Is yours bad?
Greg Hnat
98 Jeep Cherokee
Old 05-23-2008, 09:36 AM
ghnat's Avatar
Jim,
After looking at the Bentley manual the red part is the Full Throttle switch (same as WOT I guess) .
Greg Hnat
98 Jeep Cherokee
Old 05-23-2008, 09:40 AM
jmshepard's Avatar
It's not bad as far as I know.
I am working on using a Carrera manifold assembly with a Megasquirt ECU. I was hoping that the device was a TPS so that I would have to fabricate something else...
Well, I had nothing else to do this weekend.
2009 Cayman
Old 05-23-2008, 09:44 AM
Zeke's Avatar
You could find out with a meter. If it has a variable scale rather than open/closed, you'd have what you need, correct? I'm still trying to understand these OBDI cars, but many (other makes and models) seem to have a TPS(ensor) rather than just a switch. But, the air flow device may be responsible for the signals needed by the DME in this case.
The diagram in the Bentley shows only a set of contacts in the TPS.
Old 05-23-2008, 10:08 AM
db_cooper's Avatar
I'm pretty certain it is only a switch. Took one apart years`ago. Had two sets on contacts. One was for idle and the other for WFO. Input to the DME for idle circuit and full throttle maps.
Old 05-23-2008, 12:51 PM
jmshepard's Avatar
Milt,
I ran an Ohm check on the device looking (expecting) for the variable resistance. When it didn't manifest itself I went to the PP forum.
I called this afternoon and ordered the TPS from Clewitt.
Jim S.
2009 Cayman
Old 05-23-2008, 01:00 PM
DUK DUK is offline
DUK's Avatar
Jim, I used a tps from a 95 993. it was simple to make a mount for the tb and is readily available. I can send you the info if you want.
Where are you in NC?
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 05-23-2008, 02:40 PM
jmshepard's Avatar
Duke,
Livin' the dream at Ft. Bragg.
Please send the info.
Jim S.
2009 Cayman
Old 05-23-2008, 03:19 PM
David's Avatar
I used a Bosch TPS part# 0 280 120 400 000
I don't know what it's supposed to fit, but it works on my Carrera intake.
Old 05-23-2008, 03:35 PM
jmshepard's Avatar
David,
Does that TPS use a 3 pin connector?
Jim S.
2009 Cayman
Old 05-23-2008, 03:58 PM
David's Avatar
No, I think it's 6 pin, but I think I only used 3 wires.
Old 05-23-2008, 06:14 PM
jmshepard's Avatar
okay...this sounds like the same item that Clewett Engineering is sending. The TPS uses the first 3 pins the remaining 3 are for WOT and throttle closed. Thanks for the info!
2009 Cayman
Old 05-23-2008, 06:17 PM
tomeric914's Avatar
Old thread, I know, just cleaning up...
Bosch part number 0 280 120 400 is the 6 pin TPS from an '86-'89 944 Turbo which is commonly used when converting the 3.2 Motronic system to an aftermarket ECU which requires a variable output from the TPS.
This part is also offered by our gracious host under Porsche part number 951-606-113-00-M14
This is a direct bolt on to replace the 3 pin throttle switch on the side of the 3.2 TB.
Old 11-13-2011, 07:35 PM
