Question Turbo Identity Crisis?
OK, I’m in need of some expert assistance. What kind of Turbo is this?
These are the details:
This photo is taken from my 1985 Euro 930 Turbo. When I purchased the car it only had a catalytic test pipe installed. This means it had no muffler! So I wanted to replace this POS with a good muffler. I figured my safest bet would be a Euro 930 muffler with the twin exits on each side. This was the factory muffler so it should bolt right up. So I finally found a nice Euro muffler and started my quest to install it. Well, after removing the rear bumper, bumper shocks, and test pipe I am unable to fit the Euro muffler. It appears that the twin muffler exit that goes to the left of the car hits the Turbo housing preventing me from aligning the four Turbo studs with the muffler. This leaves me to believe this isn’t a standard K-27. No matter which way I twist and push the muffler, it won’t align with the Turbo studs.
Additional details:
On the large left side of the Turbo housing I have the following numbers listed:
5326-970-3870 – Listed on a green tag attached to the Turbo.
5328-151-5792 – Listed on the backside of the Turbo housing.
5328-101-5090 – Listed in large letters on the housing.
Any thoughts?
Old 07-24-2001, 05:35 AM
jbailey930's Avatar
Send a message via AIM to jbailey930 Send a message via Yahoo to jbailey930
Post
Hammer
I am at work and can't check part #. Maybe later. Here's a link to a good turbo information site http://www.3k-warner.de/english/produkte/bauprogrk.htm
I'll try to get back later if you don't hear back. Good luck
John 79 930
Old 07-24-2001, 07:04 AM
