Bigbartguy's Avatar
emergency brake light problems
My brake sensor warning light is coming on from the handbrake. If I push down on the handbrake slightly, the light goes out.
Is the switch bad?
Has anyone had this problem ?
Does anyone have a solution ?
thanks !
Tim
Old 03-27-2002, 06:43 AM
gblumenstock's Avatar
Sounds like the rubber boot is keeping the switch slightly open. Try repositioning the boot so the handle will sit flat.
I had the same problem.
GB
Old 03-27-2002, 11:04 AM
Hilbilly Deluxe
emcon5's Avatar
The switch can also be adjusted, and rides in a channel on the brake lever. You should be able to move it down (I think) to set the position required of the lever to trip the light.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-27-2002, 12:49 PM
