Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Dkennel's Avatar
wipers only park in cold weather
My wipers don't park and the interval doesn't work.
I have not figured out my wiper problems, have researched all the wipers don't park posts. I took the wiper switch/lever apart, but no luck there on the contact repair/bending. My next "suspects" are the wiper relay behind the instruments and the motor itself. I think I have read the park mechanism is actually inside the motor??
We have had a couple of nights now with temperatures close to freezing. I had to use my wipers on one of those mornings and to my big surprise both interval and parking worked without any problems! Then later in the afternoon as it had warmed up I was back to no interval and no parking.
Does this make sense to anybody? Could it be a clue as to what is not working? I confirmed it on a second day, same thing if overnight temps are around 32 wipers park, as it warms up I loose park function and interval....
Very strange...
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 11-14-2011, 06:08 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wipers.
Very strange...
Possibly the intermittent wiper switch located on the dash board?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-14-2011, 08:51 AM
Dkennel's Avatar
i doubt the intermittent switch, it turns wipers on and off as I switch it, when it is warm the interval doesn't work and wipers don't park, in cold weather around freezing the interval and the parking work.
Essentially when the interval doesn't work it is just that the parking doesn't work, if that makes any sense, in my mind interval just means the wipers have to park repeatedly....
I wonder if I should try the intermittent relay? Or do you guys think it is the motor?
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 11-14-2011, 09:50 AM
Do you have a Bentley Manual?
1986 911 Targa.
Only in L.A.:
Old 11-14-2011, 10:03 AM
muck-raker
kidrock's Avatar
I believe it'll be a dirty intermittent switch. I think if you clean up the switch with some electrical contact spray, your problem will be solved.
I once had a "parking" problem that would come and go. I wound up repairing the washer stalk, which solved my problem. Try cleaning your switch first.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-14-2011, 10:25 AM
I had the same problem - wipers would not park and the intermittent switch did not work. The problem turned out to be a dirty internal wiper motor disk for the parking mechanism. I had to remove the wiper motor, disassemble and clean.
I have a 1975 911s, and this is how the wipers work:
The wiper switch consists of terminals # 53a, 53, 53b, 53i, 53e, and 53c. During wiper park cycle, 53e (blue wire) is connected to 53a (red/white wire, +12 v all the time). The connection is made when the wiper switch is off and the motor is not in the park position. The motor makes connection between 53e and 53a with an internal disk. The wiper switch connection between 53e and 53 puts the wipers into the slow mode, until the disk inside the motor turns to the park or off position.
53a Red/white = +12 v all the time
53a Black with noise reducing capacitor to Red/white = +12 v all the time
53 Black/red (violet?) = slow speed wipers
53b black/yellow = medium speed wipers
53i green = fast speed wipers
53e blue = park at slow speed
53c black = washer pump motor
Rex
1975 911s and 2012 Range Rover Sport HSE
1962 BMW R50/2, 1995 BMW R1100RS
Old 11-14-2011, 11:03 AM
Dkennel's Avatar
what is the internal wiper motor disk? how does it get dirty? I wonder if that could be my root cause?
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 11-14-2011, 11:42 AM
First try the recommendations from the previous posts.
As for the motor disk-friction from ongoing usage.
Electrical Troubleshooting
1986 911 Targa.
Only in L.A.:
Old 11-14-2011, 01:16 PM
1984 3.2 Carrera
911Texan's Avatar
I'll post this here as well in case anyone wants to use the diagram to explain the problem being described. I can't figure it out on my '84T either. But I will!
Pilot | Musician | GM of Sky-Tec Lightweight Aircraft Starters
1984 Porsche 911 Carrera Targa & a couple Jeep TJ's
Granbury, Texas
Old 02-29-2012, 06:19 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
