pushing on dog-gear, 915 rebuiliding?
Hi folks,
I'm trying to push on a new dog-gear onto 1st in my recently disassembled 915, and I can't seem to get it on straight. I've tried a few approaches, using a C-clamp, or a gear puller (image shown here), using the P226 too so I can handle it better, and some propane heat. I'm wary, given Zimmerman's advice that slight cocking will break the ring. Any suggestions for approaches to try? Is a little cocking during installation ok, or should I immediately back out (as I have been)? Thank you, Babak
Navin Johnson
Are you heating it? or trying to put it on cold?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
they're swaged after installation by the factory, so that swage is still there after removing the original teeth. that's what makes it hard to get the new one on. i dress the swage a bit with a file. don't remove it entirely. a 36mm socket on top and a press works wonders. never tried it with stone knives and bearskins.
I thought I was all homo-habilis with the P226 tool - but you're right, without a press I'm really back in the Bronze age =).
I was heating it while in the P226 tool and then pushing it on. Off to the hardware store to buy some files, thanks for the tip! While I have you guys here, on an unrelated note, do you see anything wrong with shaving off the flange of a new DEC catalytic converter? Its diameter is 2 mm too big for even the gasket, so I was thinking of grinding the whole lip off. ![]() Thanks! Babak PS yes, I just hijacked my own thread. Lots going on in this little garage. |
abit off center
I never had any luck with heat. Those notches have to all line up and if you heat it the ring is larger and the notches will not line up.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I did a little shaving, and tried a little more heat - it's going on easier, but still cockeyed. Should I be shaving more? Should I keep pushing even though it's cockeyed?
abit off center
It has to be straight! Thats the key to getting these on, once its straight it will press right on.
Move your cP over to the top a little (in your photo) and keep pressing. It will straighten out. Unless you are using a really big press, you are gonna have a hard time breaking anything.
I have done this job with hammers, a vice and a hydraulic press. The press is easiest but they all can work. Grab your balls and crank that b!@tch... YMMV
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
gearhead
You need a press. The way you are trying to do it won't get it on there properly. If you keep screwing about the way you currently are, you are going to compress the inner bore of the gear and have to hone it after you get the dog on. You need to be sure to check the hone regardless once you get it on.
Regards, Matt
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Diss Member
There are two sides to heat... Freeze the other side. An hour in the freezer might do the trick.
Also check the side that is still up. Maybe the swaging is still a bit proud there. Quote:
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I put my gear in the freezer. Maybe over night, but at least an hour or two I think. Then I used a vice to press them together. It might be that clamp youre using.
Matt. 83 911SC 85.5 944 NA - Sold |
just find a shop with a press. then slip in the cage bearing and it's inner race and be sure there's no binding. the area inside of that flange distorts easily. i saw a 914 once where the cage bearing froze up inside 1st gear and the rear wheels locked up, skidding the car to a stop. it wasn't in 1st at the time either. an hours old rebuild from a local shop.
