tassie targa 76's Avatar
911 s ?
just trying to work out the differences in a standard 1976 targa 2.7
chassis number 9116310836
and an S model
some info i have read suggests that the 3 indicates a 2.7S motor where as a 1 would be the standard 2.7 the engine number starts with 636
either way i would like to know the differences
any help would be appreciated
Regards Michael
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 11-15-2011, 07:38 PM
I suggest you seek out / purchase a "Redbook" it will help you answer a bunch of these type of Porsche questions.
73 911 T MFI Coupe, Aubergine
Old 11-15-2011, 08:06 PM
RETIRED
Joe Bob's Avatar
In the mid 70s not much. The redbook says that the S was the only US model besides the Turbo (page 42). Bruce Anderson's book states HP at 165.
2012 ML350 3.0 Turbo Diesel
Old 11-15-2011, 08:12 PM
RETIRED
Joe Bob's Avatar
Further, the redbook
6369001-6369435 were US 48 state Sporto engines. 8/75-7/76 production of 1,576.
6460001-6462305 - US 48 state 'S' models, 2,079
6566001-6561837 -CA 2,175
6569001-6569160 CA Sportos, INCLUDED in the production number above if I read it right....
Old 11-15-2011, 08:21 PM
76 911S Targa
Depends where your car was sold. If it is a US car the only models were as Job Bob says: 911S was the "standard" US model. According to Ludvigsen the ROW 911 came in three flavors: Turbo, Carrera 3.0 (like the turbo but with higher compression pistons and without the turbo) and the ordinary 911, rated at 165 hp at 5800 rpm. Likely this is what you have. Ludvigsen's description of the 76 ROW 911 sounds very like the US 911S and may be the same engine since they are both rated at the same horsepower. You probably escaped having the smog pump and thermal reactors which were fitted on US cars, at least in California.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-15-2011, 08:36 PM
RETIRED
Joe Bob's Avatar
If you can get the engine type number, I can trace it further. 911/80 thru 94 is what I'm seeing....
Old 11-15-2011, 09:05 PM
not sure what engine type number is
but the car is and Australian delivered 1976 targa with the engine number of
6361760
5 speed manual and i think a 915\44
no AC
what other difference should i expect eg AC electric windows, mirrors
Old 11-16-2011, 12:02 AM
tof2.7's Avatar
you can have all information on the www.2l7registry.com
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77
Old 11-16-2011, 02:43 AM
