Brake Pedal Seems to Require More Pressure
I just put the car back together, after a few weeks of engine out maintenance. Now I think the brake pedal requires more pressure to stop than before. I think I know this car, but am I just being wimpy? Or did I forget to hook up something? I didn't even touch the brakes, but could I have missed a vacuum line? Suggestions?
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
RETIRED
My 83 SC has a brake booster that has a vacuum line...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Sooo, should I just stomp harder on it? Or check something? Any ideas?
you probably attached the brake booster vacuum hose by #3 cylinder, right? that hose can get cracks in it down past the transmission, to where it attaches to a tube from the tunnel, so get under there with a flashlight for starters.
Formerly reformed
Did you buy/adopt a cat?
This can cause a loss of manliness and make things seem harder.
1968 911P (Paperweight) |
oh no! that might be the answer!!
![]() ha ha , no, this guy has lived here for a long time. I must go look for vacuum lines .....
