1986911's Avatar
Just cleaned up wheel wells and need info on color
Got a tip from a fellow pelican on how to make undercarriages and wheel wells like new. Check out pictures below. Car is an 89 Factory Slantnose. I used a hot water pressure washer and the undercoating and grime came off like "Butta." Anyone have a know if that tan color is factory? I am in the process of restoring it to as close to concours as I can get and want to know if they need to be black (like the body) or this tan color that is the same as the undercarriage. I think it should be Tan if so where can I find it!!! Did the whole search thing but that lead to more confusion.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 11-12-2011, 03:15 PM
RETIRED
Joe Bob's Avatar
Chemicals|WURTH USA Inc.
2012 ML350 3.0 Turbo Diesel
Old 11-12-2011, 03:24 PM
I think after 73 everything should be body color.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-12-2011, 04:46 PM
nice job.
I think you stripped the paint right off, the beige is more than likely the actual rubber gravel guard .
Scrape into the rubber gravel guard and see what the colour is below the surface. The underside is usually painted body colour.
Old 11-12-2011, 04:50 PM
Super_Dave_D's Avatar
+1. In your case it should be black
Originally Posted by herman maire View Post
nice job.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 11-12-2011, 04:58 PM
deshetlr's Avatar
Nice looking undercoating. Should take the black spray paint well.
Old 11-12-2011, 05:12 PM
deshetlr's Avatar
Wurth makes the undercoating.
Old 11-12-2011, 05:14 PM
RETIRED
Joe Bob's Avatar
With those body mods it has had quite a bit of work. MY guess is the grey is over the original body color. I doubt very seriously that the pressure washer peeled paint off.
Paint it whatever color strikes your fancy. Wurth is pricey.....but it does a good job.
Old 11-12-2011, 05:18 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1 Not a chance looking that uniform.
Edit - those little spots just above the cadmium plated AC line fastener look pretty black to me.
Old 11-12-2011, 06:08 PM
1986911's Avatar
So far then black?
From most of the pictures I have seen the cars have black wheel wells. Actually I have not come across one with the beige gravel guard in the wheel wells (except mine). The underside of the car has that beige gravel guard finish as well. It took about 20 minutes to do each wheel well start to finish, hot water pressure washers are incredible.
Old 11-12-2011, 06:25 PM
orange with racing stripes
Old 11-12-2011, 06:29 PM
Bob Kontak's Avatar
Here is my pals 1989 regular 930 from today. It has 20k miles. I will ask him to look in the morning at his wheel wells.
Old 11-12-2011, 06:33 PM
1986911's Avatar
No body mods, car is an original 1989 factory slant nose. I spoke to the original owner after I bought it and she drove it right off the showroom floor. Its been Black from day one. Beige wheel wells on all 4 sides. Check out a picture of the front well opposite side
Bob Kontak's Avatar
Sorry - here it is. Looks a lot like your wheel wells. I will confirm for you. My 81 SC wheel wells bottom are red. This 930 does not have a hint of black like the outside.
Old 11-12-2011, 06:34 PM
1986911's Avatar
Sweet, Bob what is he going to do to it? I have a lift as well but did not have the guts to pressure wash inside the garage, way too much gunk and grime.
Old 11-12-2011, 06:39 PM
Bob Kontak's Avatar
He is actually cleaning the engine and banana arms, etc. He sent me this pic with the text "Call me Dexter" which I think refers to the HBO show where the guy must wrap his murder scenes in visquene (sp?)
He has an epoxy paint floor but no drain plus he is pretty "clean". I have an e-mail out to him now re the wheel wells.
Here is a pic of both our cars together.
Old 11-12-2011, 06:56 PM
1986911's Avatar
Thanks Bob,
Targa's rock!
Old 11-12-2011, 07:10 PM
Cooper911SC's Avatar
Hi, Nice looking Slant Nose!
Kudos for tackling your undercarriage.
I prepare Porsches for Concours for a living. I have taken care of undercarriages on '81, '84, '87, and several '90s 993 series cars.
What you will find is that Porsche used a Beige paintable undercoating applied over the sheet metal.
The car then went down the paint line. As the car was sprayed the flat surface facing outwards in the wheel well was given a medium wet coat of body color paint. (In other words looking straight into the wheel well with wheel off of the car you will see body color) This paint will just cover the undercoating. The front wells always appear to get more paint as they are a bigger more visible area than the rears. The wells will not be fully painted as the rest of the car.
Likewise, the floor pan will be 95%+ just the beige undercoating as your picture looks.
There will be some color on outward facing edges. These areas would have been hit by "overspray" as the rocker panels and door jambs were painted.
When I handle Concours prep on undercarriages I work slowly by hand with mild solvents to avoid damaging the paint or undercoating. The Tectyl or Cosmoline coating is time consuming to remove.
You can use a gloss black spray can to "repaint" your wheels wells.
Once clean and dry I hand wax the wells and the floor pan of the car.
Just my observations and $.02
Best regards with your detailing!
Cooper
Old 11-12-2011, 10:00 PM
1986911's Avatar
Thanks for the reply Cooper. So when I apply the paint to the wheel wells should I go for 100% coverage (no beige showing) or spray sparingly so some shows here and there? I would greatly appreciate any pictures as well.
Thanks!
Old 11-13-2011, 07:18 AM
nineball's Avatar
now that's dedication, bordering on ocd
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-13-2011, 07:57 AM
