Josh
Respirator?
I am starting to plan for painting my car in the spring. It will likely be the only car I ever paint although it will happen in a few separate stages - exterior, interior, trunk, and engine bay. I will put together a paint booth in my garage with 2 or 3 intake and output fans each. What is the consensus on respirator type? If I am only doing one car (I will also wear it for stripping/blasting) should I get a fresh air system or is a cartridge system adequate?
Thanks for the input.
Old 11-23-2011, 06:08 AM
RETIRED
Joe Bob's Avatar
Look up isocyanates.
2012 ML350 3.0 Turbo Diesel
Old 11-23-2011, 06:27 AM
Josh
I saved an ebay search for a used fresh air system.
Old 11-23-2011, 05:48 PM
abit off center
cgarr's Avatar
I started using a fresh air system about 10 years ago, the problem is the 20 years before I had it. Don't screw with your lungs.. You can even make your own pretty easy..
______________________
Craig
G2Performance
Old 11-23-2011, 05:52 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I am not going to recommend an old fashioned cartridge respirator. But one car...... and you are evacuating the fumes quickly??
Cartridge filters absolutely kick a*s when they are brand new.
Also, will you spray with old gravity feed or HVLP? HVLP will have less overspray.
I know what I would do but it runs against the current school of thought.
Old 11-23-2011, 06:25 PM
Bob Kontak's Avatar
What do you drive the fresh air with?
Old 11-23-2011, 06:27 PM
Bird. It's the word...
Fishcop's Avatar
Fresh air system. Every time for an enclosed space. I bought a second hand unit and hooked it up to my scuba tank and 1st stage regulator.
Having said that, I did a lot of my prep work and body underside work outside and just wore a cartridge filter. As Bob K mentions, the modern cartridge filters are very good when fresh and used in accordance with instructions and capabilities, don't skimp - change the cartridge regularly to manufacturer's recommendation (use a prefilter and an organic solvent spec cartridge). You can preserve the cartridges by putting them in an air tight container (Tupperware) in the fridge.
Also, if you are "bearded" or otherwise facially hirsute, then you really want to consider a shave when using a cartridge filter or 'smoothing it down' with vaseline so that the mask gets a seal... otherwise it's pointess.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-23-2011, 07:39 PM
RETIRED
Joe Bob's Avatar
They make hoods for people with facial hair.....
Old 11-23-2011, 08:06 PM
Fishcop's Avatar
I just like smearing vaseline over mysef
John Forcier
Old 11-23-2011, 11:26 PM
RETIRED
Joe Bob's Avatar
tmi.....
Old 11-24-2011, 04:07 AM
