-   -   No left side running lights (http://forums.pelicanparts.com/porsche-911-technical-forum/641200-no-left-side-running-lights.html)
Porchcar guy 11-21-2011 09:08 PM
79 SC ....Noticed tonight that my left side tail light was out and when I walked around the car..the front left running light was also out. Pulled the lenses, checked the bulbs, looked at the sockets and went to the fuse box. Fuse #4 was blown and when I replaced it, the new fuse blew as soon as I pulled the light switch. I am an electrical minus ...where should I start ?
DRACO A5OG 11-21-2011 11:17 PM
There is a short in the system, most likely a ground in the rear housing possibly the front but rare.
Check to see if the ground came loose or worse the PCB type contact has not broken, if broken JB weld a piece of plastic to re-build the PCB type contact board:
http://img.photobucket.com/albums/v5...702_202317.jpg
Mine actually cracked in half due to all the years PO was smashing the bulb into place think it would make a better contact, NOT :eek:
Jim
village idiot 11-21-2011 11:46 PM
Jim
Exact same thing happened to me. I ended up making new grounds for both tail lights. No problems since:D
Porchcar guy 11-22-2011 09:38 AM
Thanks guys...I should also have said that all other functions are good on that side ... flashers, turns, brakes, back up lights. I will try to find the ground issue tonight and let you know. According to the Bentley, I can remove the rear housing fairly easily. The front requires removal of the bumper...Grrrrr !!!
Bob Kontak 11-22-2011 02:31 PM
Disconnect the wires from the engine bay light and see if the fuse does not blow.
kidrock 11-22-2011 05:10 PM
I'm with Bob on this one. It sounds like a classic case of the engine bay light having an issue. The left side running lights route right through this system. Check your light fixture very carefully.
Bob Kontak 11-22-2011 05:31 PM
=kidrock;6387399sounds like a classic case of the engine bay light having an issue.
I am not sure how easy it is to just disconnect the wires. Pull that bad boy off and make sure the wires are not touching anything and put a new fuse in.
Betcha!
Porchcar guy 11-23-2011 06:32 PM
shoulda Betcha Bob,
It was a pinched wire in the rear of the rear tail light housing and now she is good to go..until the next time on this wonderfully cranky 32 year old girl. Thanks for your input...gotta love this forum...everybody steps up to the level of their ability !!! My learning curve is steep right now and will get steeper as I get more familiar with "Molly".
Bob Kontak 11-23-2011 06:42 PM
Thanks for clarifying the resolution. Finally, DRACO and Village Idiot, at long last, have some "street cred" http://forums.pelicanparts.com/suppo...leys/freak.gif
DRACO A5OG 11-23-2011 09:30 PM
I am humbled BK :D
Porchcar guy 11-24-2011 12:31 AM
AH SHUCKS, Jim...U B blushin :=)
kidrock 11-24-2011 01:52 AM
To steal a line from Capt. James T. Kirk: "Dammit, Jim!!!!"
Spot on diagnosis. You rock!!!
