 I PASSED The Dreaded CA Smog Test Hello Everyone. I'm completely jazzed today. I took my Targa in for the smog check and passed. Although my car runs great I was a bit worried cause my car has 230,484 miles on the clock. (1984 Carrera with a stock 3.2) Here's what I did to prep for my smog check. 1) Plugs, Cap and Rotor. 2) Replaced the air filter. 3) Replaced the O2 sensor (even though the old one only had 30k miles on it.) 4) Change oil and filter. 5) Cleaned out all the breather hoses from any oil residue. 6) Inflate rear tires to 40 psi. 7) Drove the car prior to test making sure engine was up to running temp. Also what I'm going to do now is remove the CAT and replace it with a test pipe so I can save the life of the CAT for next time. See you on the road. |
 Yeah, but does your clock work?   Congrats..... |
 Congrats, my 86 just passed with 178 k, although only 25 k on rebuild. Nothing done to car for prep. Everything stock. |
 :rolleyes: Shot in the dark.....:p |
 please post CA passing results if you have a second. A possible drawback to passing very clean is that the CARB might lower the cut points for your year car - they have done this in the past. It is good to pass with a well operating smog system but let's not strive for ultra clean as we may penalize those that have a cat on the margin by subjecting to lower cut points and spending $$$ for a new cat. |
 I will post the smog test results later this evening. |
 Smog Test Results Here are the smog test result from my current test. :cool: http://forums.pelicanparts.com/uploa...1322152359.jpg Here are the test results from 2009. http://forums.pelicanparts.com/uploa...1322152398.jpg Notice how they lowered the MAX levels for the HC, CO and NO. |
 It seems to be difficult to pass this smog test in CA. Is there not guys who control , more coolest than others ??? If you see what i mean ??? |
 Your point well taken. Quote:
 Anybody? http://forums.pelicanparts.com/uploa...1322153121.jpg |
 Who is up for this ? |
 Always been my argument....how can they make a stricter standard w/o legislation?  I think it's illegal. |
 I wonder if some cars "as manufactured" would fail the current CA smog test. It is absurd to apply current requirements to older cars. I think that 3.2 Carreras were probably very clean for a 1988-built car owing to the EFI setup.  Ohio is not nearly as tough where testing is required. Here is my test on my very stock 88 Carrera with 46K from last year: HC PPM Test 10.1 Limit 174.0 CO % Test 0.00? Limit 1.12 NO PPM Test 343.5 Limit 1258.0 CO2 % 14.96 Limit N/A |
 That's very, very interesting. I know a DMV Investigator... I'll talk to them and see what they say. |
 Your efforts. Quote:
 would be greatly appreciated by our members. It just does not seem right........ Best, Gerry |
 1 - the smog test stations have nothing to do with it, they follow the cut points coming across the connection to the CA cut point data base, CARB has innocent looking people show up at test stations to check how they operate, the station operators for the most part try to follow the rules as far as I can tell, I'm sure there are exceptions. 2 - the cut points have been lowered in some cases, don't know what cars/years/models have been affected - there is no public general quiery access to the data base other than through the cut point look up 3 - the current measurement and type of pollutant may not have been known or published when many of these cars were first sold - if anyone has this info. please post with reference 4 - CARB operates for the most part in a secret manner and they do pretty much as they wish, e.g. you didn't see a public notice informing that the cut points for cars x, y and z will be lowered. There are a few public meetings here and there, and car people get up and rant and are pretty much pushed aside and ignored as far as I can tell. If your car is in good working order it will pass easily. Probably the best thing you can do is write a letter to your local elected officials. You can call and talk to some of the people that work at CARB, some are car people but will not say much because they want to keep a job I suppose, I've talked to a couple good people. On the other hand some will say you are killing babies because you drive an old car, I've actually had that said to me over the phone. As you might tell I've dug into this a bit, I've given up, I have bigger fish to fry. Unless you have a huge amount of money we are not likely to get lawyers to dig in to suing the government, there is no money in it likely |
 The CA cut point and CARB input may not be worth the trouble of a law suit but it would be nice to know exactly how things work so we can understand how the CA cut points are calculated. |
 If the cost is distributed across a large number of enthusiasts a legal challenge would actually be a cost savings. How much did you spend prepping for your last smog test? I think we should get a test case going and then get car clubs and individuals to donate to pay the legal fees. Any judge will smack CARB back into line but only a judicial ruling can change CARB's direction. |
 I spent roughly $230 on smog prep which does not include labor; had I not done the work myself. |
| All times are GMT -8. The time now is 08:45 AM. |
