flywheel choices
My question is, if removing the DME and all components related to EFI and ignition from a 1986 Carrera, what flywheel would be best used as a replacement.
Brad search works... but very hard to get through
Brad - 86 Carrera (Doc) |
Flywheel
If you don't need triggering a late 3.0 FW will fit with the 3 bolt pilot brg, for that matter an early will fit with the press in pilot, but it boils down to what gear box, what style clutch, and street or track.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
So any flywheel with same bolt pattern should work with a 915 tranny. Good to know - thanks
BG
Fw
any 3.0 or early 3.2 pre G50 will fit the 9 bolt crank and a 915, the 240 mm turbo will not fit a 915 but it will fit the crank.
Mike Bruns
AutoBahned
There are lots of light wt. options too if that is what you want. |
