-   -   I'm going to change my oil tomorrow - thinking of adding Seafoam today (http://forums.pelicanparts.com/porsche-911-technical-forum/641291-im-going-change-my-oil-tomorrow-thinking-adding-seafoam-today.html)
Tidybuoy 11-22-2011 10:45 AM
I'm wondering what the experts think....
I'm going to change my oil either tomorrow or Friday and so I was thinking of adding a can of Seafoam to the oil today - as a general engine cleaner. I've heard of people adding Seafoam to the oil but I hve never done this myself. Are there any benefits to doing this?
Thanks.......Vern
mholbrook38 11-22-2011 11:01 AM
I generally add Seafoam to gas to clean the injectors. I don't know about to the oil. Lots of us "old timers" grew up adding a quart of ATF to the oil for a couple days before an oil change. Very high detergent. I don't know how this would go over with our Porsche people.
Eagledriver 11-23-2011 04:12 PM
I would only do this if I had a problem I was trying to fix. Maybe a stuck ring or clogged cam spraybar. If your car has had regular oil changes and has no issues, I wouldn't do it. Best case is nothing bad happens, worst case is some sludge comes off and clogs a bearing, spraybar, piston squirter, pressure relief valve, etc.
-Andy
dshepp806 11-23-2011 04:27 PM
I wouldn't, either.
Doyle
Oh Haha 11-23-2011 04:31 PM
Don't do it.
I dig SeaFoam but only as a fuel additive.
If I had a car with issues I may try the vacuum hose route but not in a good running engine.
DRACO A5OG 11-23-2011 09:58 PM
+1 Don't do it!
Tidybuoy 11-23-2011 10:43 PM
Got it. I won't do it. My car is in good shape and just needs and oil change. It was only a thought.
LakeCleElum 11-24-2011 04:16 AM
I still add the AFT to some of my vehicles, but not my Porsche. It's unbelievable how clean the engine it is upon diassembly.
kwikt 911 11-24-2011 04:56 AM
No.
charlesbahn 11-24-2011 05:52 AM
I've put it in the oil of a 3.2 that wasn't running well. Cleaned out the mosquitoes from the whole neighborhood.
Didn't solve the problem, replacing the speed/reference sensors did, but didn't seem to hurt the engine, and that was a lot of miles ago.
Does wonders for snow blowers, lawn mowers, etc.
Like other have said, if it ain't broke, don't fix it. I wouldn't put it in unless I was having a problem.
Just my .02
Joe Bob 11-24-2011 07:47 AM
Put it the gas and run it for a couple of days.....it'll end up in your oil anyways.
kidrock 11-24-2011 06:44 PM
I used to run a can of B-12 Chemtool through my oil for about 100 miles before an oil change in many of my old cars, just to clean up the crankcase. It never hurt anything.
enzo1 11-24-2011 07:36 PM
more info, just curious ....through the valve guides?
Joe Bob 11-24-2011 07:43 PM
Seafoam washes down everything past the rings and your oil ends with all the crap it breaks loose. It's recommended that after you do a treatment that you change the oil....
enzo1 11-24-2011 08:34 PM
oh, yeah, duh... I meant rings, didn't think about the crud, though
