Senior Member
How to remove the "Targa" emblem on the rollbar?
As it says above, I need to remove the targa emblem on the right and left side of the rollbar.
Assume that the fasteners are on the inside of the rollbar behind some of the fabric or vinyl? Any tips on getting to it? Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Checked out
It's a big job. You need to remove the outer rollbar covering (the outer skin that the emblem is attached to) to get to the fasteners.
'73 911 T Targa
I haven't done this (yet), but I've read up on it. Based on what I've read, there are two studs on each side of the targa bar that extend into forward part the rear wheel well. They're probably rusted and can easily snap when you go to loosen them. Be careful and use solvent that loosens rusted threads. After that, there's a bunch of screws behind the seal along the top. Once that's apart, it's off.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
RETIRED
Are you planning on painting the Targa bar? If so...one of those wire saws.....kinda like an OSS garote will work.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Senior Member
JB,
Was going to paint the roll bar but go back with the stock satin black color. I now have a factory fiberglass hard top and its going to be the body color. The guy helping me was wanting to do the roll bar to make it look as nice as the body color. Joe
Senior Member
Thanks for the tips guys. Jeez the emblem is $63 bux each, so too expensive to just pry off and put new ones on.
Joe
