Banned
Opening up "elephant ears" mirrors
How to disassemble / open the elephant mirrors to get to the electrics ?
Electric mirrors......
Assuming they are like the ones on my SC, gently pry the glass from the base with a small screwdriver. Once loose, pull the heating connector off. Then you will see 3 6mm screws. Remove them and the motorized unit will come out. Separate the master plug and you are done. If you want to remove the mirror completely, you will have to push the pins out of the body half of the master plug. There is a special tool for this, but it can be done without it. There is a small plastic plug on the glass side of the base. Remove the plug and loosen the allen head bolt. The mirror base will be loose at this point. Pull the wires thru the base and you are done. As is said, "assemble in reverse order". Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Banned
Thanks Fred, i already have them out of the car. Should be easier.
Banned
Just pull it apart... Never imagined a mirror could be so over-engineered and it's all metal not plastic as i supposed.
It's (was?) the Porsche way. Last edited by prebordao; 10-09-2011 at 10:15 AM.. Reason: Typo |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Hint.
When you re-mount the mirror, take care to not over-torque the mounting screw.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-09-2011 at 01:19 PM.. |
1980 911 SC
Second, the mirrored glass has a metal backing......do you pry it apart between the glass and metal backing? Does the glass just pop off? Is it that easy? Just want to make sure.
Life's a Beach |
This is how I removed the mirror from the housing. I moved the mirror by hand to the extreme sideways position. Then I could stick my finger into the gap between the glass and the housing. I pulled carefully and with some force the 3 prongs came slowly lose. They stayed intact. I disconnected the two heater wires from the back of the mirror glass. And that is how the mirror glass looks from the back side.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
That was well explained..much appreciated!!
muck-raker
thanks Porwulf, very well explained. I've got this project on the back burner for some time....gonna need to get on it sooner or later.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Senior Member
Agree, excellent thread!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
