-   -   1973 RSR width? (http://forums.pelicanparts.com/porsche-911-technical-forum/642411-1973-rsr-width.html)
avorkinn 11-29-2011 12:18 PM
1973 RSR width?
Can anyone tell me the total width of a 1973 RSR?
wayner 11-29-2011 02:33 PM
THIS wide
http://forums.pelicanparts.com/uploa...1322609604.jpg
wayner 11-29-2011 02:34 PM
OOPS, wrong picture.
THIS wide.
(I can take some measurements of mine later this week)
http://forums.pelicanparts.com/uploa...1322609647.jpg
AirKuhl 11-29-2011 03:18 PM
How precise do you need to be? The Googles say that a 930 is 69.75" at the rear flares. The RSR flares are not exactly the same profile as turbo flares but it should be very close. You can click the pictures in this gallery to get very high res shots of the flares to compare.
1973 Porsche Carrera RSR #0... 1973 Porsche 911 Carrera RSR Photo album by Rsr73
Bill Verburg 11-29-2011 05:52 PM
http://forums.pelicanparts.com/uploa...1322621531.jpg
Bob Kontak 11-29-2011 06:31 PM
Sweet. 2015 pounds.
Conversion order 491? Difference between a base model and the RSR?
Flieger 11-29-2011 08:15 PM
Yup. M471 = RS Lightweight. M472 = RS Touring. M491 = RSR.
avorkinn 11-29-2011 09:55 PM
This says 65 inch but must be wrong, looks more to be the width for the 2.7 RS?
Originally Posted by Bill Verburg (Post 6400482)
Bill Verburg 11-30-2011 04:20 AM
Unfortunately the width is most of the spec sheets is the max width which is at the mirrors. So the RSR an RS will appear to be the same width
the rear track for the RSRs varied from 56"(1421mm) on the '73 2.8RSR to 60.2"(1528mm) on the '74 3.0 RSR
avorkinn 11-30-2011 10:32 AM
I canīt understand that the mirror extend the aft fenders on the RSR and did not both the RS and the RSR came with mirror only on the drivers side?
I think I have got the answer, 70,7 inch, fender to fender.
Bill Verburg 11-30-2011 02:53 PM
I don't know where R/T got their measurements
here are the factory widths
930 1775mm(69.9")
SC/Carrera 1652mm(65.0")
the '73 2.8 RSR would be very close to the 930
the '74 3.0 RSR would be a couple of inches wider
I'm also sure that there is some variation in the earlier flares as they were hand installed until sometime in the late '70s
