horn pad removal
Hello- I have a new-to-me 76 with the later 3 spoke wheel and horn pad. In 101 Projects and here on this forum it is said that the horn pad will pop off with finger pressure. Mine will not. Is it possible to pry it off? Where do you pry? Do you pad the pry tool contact points? What tool is best? Thanks for your answers.
Old 11-29-2011, 03:53 PM
Pull around the edges with your fingers and it pops off. There really isn't much to it. I took mine off last week.
Old 11-29-2011, 03:56 PM
Detached Member
Hugh R's Avatar
Yep
Hugh
Old 11-29-2011, 04:35 PM
gtc gtc is offline
abides.
gtc's Avatar
Sometimes they are pretty tough to remove. Also, the plastic clips sometimes break (no way to avoid it) but they are replaceable.
Graham
1984 Carrera Targa
Old 11-29-2011, 04:39 PM
ivangene's Avatar
pull and scream
Ed M
86' Coupe
Old 11-29-2011, 04:44 PM
newby
Aussie Thunder's Avatar
Yep I pulled mine off last year and a couple of the clips broke - I glued them back together as the break was clean and the same for both and PRESTO ! All good !
1989 Black 930 3.3 964 Turbo Motor 5 Speed
Ben Clark Photography
Website: http://www.benclarkphotography.com.au
See our latest work:http://www.benclarkphotography.com.au/blog
Associate member of the AIPP - Aust Inst of Professional Photographers
Old 11-29-2011, 07:13 PM
RETIRED
Joe Bob's Avatar
Helps if you have nails....
2012 ML350 3.0 Turbo Diesel
Old 11-29-2011, 07:27 PM
I'm not sure exactly what kind you have but mine had three screws that went through the back of the steering wheel 'plate' that had to be removed first.
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 11-30-2011, 01:14 AM
horn pad removal
Thanks to all-got it off this morning!
Old 11-30-2011, 07:37 AM
