911 fever
Hi guys,
New to this forum and to Porsche world, I'd like to have your help. Imagine a 911 T with official option Leather interior S instruments and Oil tank Bumperettes F/R Tinted glass light metal wheel koni shock absorbers ignition lock Fit a S engine into it... What would be needed to have a full S from a construction point of view ??? Torsion bars ? Brakes ? what else ? Tx in advance for your lights... |
RETIRED
It's always going to be a 'T' with 'S' upgrades. The VIN# will give you away.....but, The Redbook by Paternie is a good guide. Also the Early 'S' Registry is a great help.
Alloy wheels and calipers, vented rotors along with the 170hp injected engine is what I see.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Paper Member
What's the difference between an S oil tank and a T oil tank?
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
911 fever
An "S" oil tank will have a hole cut out for the oil level sender, which sends the signal to the oil level "S" gauge. A "T" oil tank does not have the hole.
Craig '69 911T |
Crusty Conservative
The S aluminum trim strips are fatter than T in front, sides, and rear.
If the T had the S gauge option, then it had an oil level sender in the tank I understand many, but not all 69 S had Aluminum decklid($$$) Bosch CD Ignition system in place of marelli coil & points Two lamps under the front bonnet instead of one in the T Completely different gearing in the 901 box Torsion bars as you said Front & rear sway bars 911S logos on glovebox 7 rear lid The 1969 was unique in one year wiring harness & some other areas for all models
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) Last edited by silverc4s; 12-02-2011 at 10:49 AM.. Reason: typos |
Torsion bar dimensions are the same.
External fender-mount oil cooler and '69 MY-only cooler lines and thermostat. Aluminum deck lid not standard in an S. Aluminum license plate panel Alloy wheels are usually deep 6x15 Fuchs, usually with Michelin 185/70-15 XWX. However, a friend has an orig. 69' S Targa (even rarer than a coupe), but it has standard 6x15 Fuchs. You can outfit your T to look like an S (insignia, etc.), but why? Those in the know .... will know it's just a nicely done poseur. Instead, enjoy it for the improvements you make to the driving experience. Sherwood |
AutoBahned
I agree, just do the things you want to have and enjoy it. Early 911S bbs knows all about the stock items on the early cars.
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S 25 992.1 GT3RS |
Factory differences between a standard factory 69S and a standard factory 69T would be:
S 3.5" spacing front struts Alloy front calipers, rotors Sway bars Fuchs wheels (.06 ending part #) F+R bumper trim Gauges Steering wheel Engine Oil System and Front Cooler Transmission Badging Possibles also include: Al decklid and license panel Sport seats Not all 69 S's had these as standard. Quote:
Tru6 Restoration & Design |
911 fever
![]() Specially to increase the driving experience
911 fever
@Shaun 84 Targa : Thanks !!!
e
http://www.autoforeignservices.com/ 57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc. |
I think I jumped the gun. Friend is 2nd owner; purchased his '69 S Targa around '72. The original owner may have installed the .020" wheels before '72 or when I was looking. 901.361.012.06 (early); aka the deep dish version* 911.361.020.00 ("flat", late version) Sherwood |
