Post How do i adjust rear koni shocks
I have a 72 911. The car is up on jack stands being put back together. While it is up i figured i would try and adjust the rear red konis. I do not have the adjusting key and it has been such a long time I can't remember how to do it. Anyone know how?
Old 07-24-2001, 12:03 PM
geoffbaltz's Avatar
Post
http://www.koni-na.com/adjustment.html
Geoff Baltz
'86 944 Turbo
http://www.ninefiveone.com
Old 07-24-2001, 02:46 PM
Post
Thanks for the link but, I'm still not sure which method i should use.
Old 07-24-2001, 05:01 PM
Early_S_Man's Avatar
Chances are about 99.9% that you have the 'standard series' 82K-1756 shock, and the part number is clearly stamped on the lower part of the body, usually requiring a bit of cleaning with ordinary mild cleaner such as Windex. If so, just use the 2nd procedure down for 76, 80, 82 series. 22 mm wrench required for lower bolt & nut, and 17 mm wrench for upper nut removal.
Warren Hall
1973 911S Targa
Old 07-24-2001, 05:51 PM
Post
Thanks geoff for the link and once again thanks warren for the part number and method to use.
Old 07-24-2001, 09:06 PM
