Carerra Headlight Troubles - Bright works; Dim doesn't
Let me first apologize if the answer to this question is found somewhere else on this board; my computer recently died I am left to surf on my phone and combing through the older posts on it has proven to be difficult.
The problem: 89 Carerra drivers side dim light does not work, passenger side dim works, both brights work.
History: About a year ago the drivers side dim bulb went out. I bought a new bulb and installed it (I can't remember if the dim bulb worked at that time or not but if it did it wasn't for long).
The initial fix: The dim bulb started working one night after a hard acceleration in 1st to about redline. After that it just started working and has worked until last night.
I have already tried the initial fix again (why not) and it did not work.
The question is: what would cause the dim bulb to not work while the bright does on one side?
Old 12-04-2011, 06:53 PM
muck-raker
kidrock's Avatar
bad bulb connection or ground. Make sure both are clean and tight.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-05-2011, 02:54 AM
I have a confession to make; one of which I am not particularly proud. Apparently the vast supply of knowledge and willingness to help that exists on this board has made me lazy. Instead of doing basic troubleshooting of a problem I can say, "I'll just ask the pelican forum, they'll know the answer right off!"
I am ashamed to admit that the headlight issue was solved by simply swapping the passenger and drivers bulbs. Passenger bulb worked on driver side.
Problem solved - drivers side bulb burnt out
Solution - buy new bulb
Installed and everything works great. I will take this a a learning experience to rule out the simple stuff first.
Old 12-05-2011, 11:00 PM
