-   -   Webber carb set up question (http://forums.pelicanparts.com/porsche-911-technical-forum/643338-webber-carb-set-up-question.html)
slow car 12-05-2011 03:03 AM
:Just ran my 3lt on the dyno and it is showing a rich spot at about 3 to 4.5 k
what do i need to change it is running F3 emulsion tubes 160 mains and 170 air correctors. Would changing the emulsions help my rich spot?
John
1QuickS 12-05-2011 09:31 AM
Not a jetting expert but F26s should help out. I'm assuming you have normal auxiliary venturis and your float levels are correct.
slow car 12-05-2011 03:03 PM
Yes i am running 34 venturi , what do the numbers mean on the emulsions is higher richer?
John
john walker's workshop 12-05-2011 04:03 PM
emulsions are all over the place with their numbers. F26 is stock. a step up to 180 air will lean out the top end, if it's still a bit rich up there.
