Engine harness connector problem
I am in the middle of getting my engine back into the hole and I have a problem with the connector at the engine harness. It happen when I disconnected the harness while removing but the wires and pins come apart on the engine side. I tried to use the color coding from the male side of the connector but I would feel a lot better knowing I had the wires correctly via Porsche specs.
Can anyone out there help? 80SC
