whats the ideal weber set up?
Guys i have a euro 76s 2.7 with cis , i am ripping off the cis and going webers (i hope) what is the best set up i;e
- 40's or 44's - what jetting would you recommend - any additional information that would help? |
I'd skip the Webers and go with 40mm PMO's.
40's with 34 vents is perfect for me
40 Zeniths would be cheaper......
a 2.7 per rpm needs a fixed amount of airflow that 34 vents satisfy i am using e-cams and 8.5:1 pistons |
There are some great posts in the engine rebuilding forum of guys going through this exactly and a lot of advice from others. You should check them out. If I was on my computer instead of my iPad this evening I would send you some links.
Carbs will work great on this engine. I'd use any of the set-ups you find on here to start with. You really will want to dyno for fine tuning, or buy a wide band O2 meter. I have a cheap WB O2 meter in my car and it is a Godsend for tuning.
-Andy |
| All times are GMT -8. The time now is 04:47 PM. |
