Heat exchanger cleaning
I have the heat exchangers off the engine- for top end.......wondering what the best way to clean the inside is? They are full of oil from the motor leaking - I did a search.......torch heat, oven cleaner, carb cleaner. I was thinking of hot tanking them.......would that work? Not too concerned with the outside.........planning to go ssi in a while....Any ideas, suggestions appreciated. Thanks - Steve '81SC
Old 04-03-2002, 06:46 PM
Senior Member
Doug Zielke's Avatar
Steve,
I had some *really* grungy mufflers for a m/c I was restoring.
I took them to a local automatic transmission shop for cleaning.
These guys had a super-hot, solvent vapor tank that dissolved years of baked on carbon and oil. Don't know if all shops have this sort of equipment, but it's worth asking around.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-03-2002, 07:06 PM
Thanks Doug
Old 04-03-2002, 07:26 PM
Senior Member
Re-read my post, Steve.
I had the mufflers from a motorcycle vapor-tanked.
Don't think they smelled, but then I was the one riding the bike!
Old 04-03-2002, 07:34 PM
jwetering's Avatar
I just went through this. I had an old oil soaked set of pre74 HX and went ahead and cleaned them in a regular old parts washer. With filthy heavy duy mechanic shop used Varsol no less.
I figured (incorrectly) that the solvent would be good and evaporated by the time I installed the HX on my car. (No wise-acre remarks from the peanut gallery there DougZ)
To make a long story short, I had to run the car for about a week before I could direct the hot air into the cab without gassing myself. A week later you can hardly tell. I expect in another week or two the smell will be gone for good.
The mech at the shop said I should have steamed them...
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 04-03-2002, 10:19 PM
Thanks J,
You confirm my suspicions...........I think I might have the machine shop the heads are at bake 'em in their oven. I definitely won't use solvents or such. Thanks again, Steve
Old 04-04-2002, 07:58 PM
