Wiring harness confusion when reinstalling my engine
http://forums.pelicanparts.com/uploa...1323282404.jpg
http://forums.pelicanparts.com/uploa...1323282422.jpg I am in the final stages of re-installing my engine. Unfortunately I took so long to do so a lot of the things I thought I would remember, I don't. And in this instance, I didn't take a pre-removal picture. Here's the deal: I have 2 12 pin wiring plugs, one by the rear driver's side tail light--I know that one gets plugged in. But the other one is behind the engine, still driver's side, and I for the life of me don't remember unplugging it when I removed the engine. But I certainly could have. What is that plug for, and should it get plugged back in? The car is a 1974 chassis with an 83 SC motor in it. No O2 sensor, if that makes any difference in this situation. Thanks--I am so close to having this done! |
The plug for the one in the back should be in the back on the shelf by the fire wall. Isn't that it in the picture on top?
You got 2 plugs, but one is a male and the other one is a female, right?
It's possible. If I remember right (and I should because I just reinstalled my engine a few weeks ago), I believe the wiring harness that the plug goes to is for all the Lambda stuff that goes to the ECU under the passenger front seat. Do you have an ECU under the seat? |
I just confirmed with the wiring diagrams. The one in the back is a T12 (12 pole) connector which serves the O2 system. If you don't have any of this, it's possible it wasn't connected to begin with.
Also, just for information, the other connector on the left side of the engine is actually a T14 (14 pole) connection. Even though it only uses 12 of the 14 available spots. |
Matt
You beat me to it. HWM If you don't remember taking them apart, I would probably leave them separated and see what happened. |
Chances are it just popped off by itself when you were lowering the engine. The bentley and 101 projects book both forget to mention this connection. I caught mine because I happened to see it in the back while I was lowering the engine. Then I remembered reading some posts reminding people not to forget it. Plug it back in and then start troubleshooting your no start problem. |
Pressure test.........
Hotwatermusic, Do a FP test and see if the FV is vibrating at the same time. A fuel gauge will tell you how much fuel pressure is in the system. BTW, fuse #18 supplies power to OXS relay. These are the basic tests. Keep us posted. Tony |
| All times are GMT -8. The time now is 06:11 AM. |
