915/72 ZF LSD code ? i search all info (draw/data ect)
hi I search the ZF code on LSD diff for gearbox 915/72 row.
this diff fit only on 915 case (type of spline...i suppose) or is "one" standard ZF diff
fit on other brand cars?
---the difference between insanity and genius is success--
Old 12-08-2011, 03:26 AM
gearhead
915/72 is a gearbox from a 3.2l Carrera. It's going to be a fine spline LSD. It is proprietary to Porsche and won't fit BMW or other vehicles that used ZF LSDs.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-08-2011, 09:56 AM
all right! thanks! ...but i see on the net aftermarket brand , this LSD is same/similar to LSD 924 turbo? (but I do not know the transaxle)
Old 12-08-2011, 10:11 AM
gearhead
The "snail" 924 Turbo gearbox is kind of a weird outlier. It is actually 915 based and uses the same LSD. However, it's got a ring and pinion in it that spins the other way.
1974 914 Bumble Bee
2009 Outback XT
Old 12-08-2011, 10:12 AM
