-   -   help with rear turbo flare alignment (http://forums.pelicanparts.com/porsche-911-technical-forum/644064-help-rear-turbo-flare-alignment.html)
kj9438 12-08-2011 05:59 PM
hi everyone , i just got my rear turbo flare yestoday , and i m try it on today , is this flare alignment see ok ? :confused:
http://forums.pelicanparts.com/uploa...1323395867.jpg
http://forums.pelicanparts.com/uploa...1323395927.jpg
jimtweet 12-08-2011 06:02 PM
DONT do any welding until you have a rear bumper on the car, that is really the only way to ling them up correctly
kj9438 12-08-2011 06:11 PM
thanx . i try with rear bumper and this is came out .
afterburn 549 12-08-2011 06:36 PM
Yes the more things that are in place will dictate your correct fitment
rattlsnak 12-08-2011 08:43 PM
dont do any welding until you have a rear bumper on the car, that is really the only way to ling them up correctly
+1.
redstrosekNic 12-08-2011 08:48 PM
Give us some more pictures of your build! ;)
kj9438 12-08-2011 10:19 PM
i also mod the 964 c2 front caliper to fit on my boge stut , by the way is this boge stut ? . the new rotor is coming soon, the back will be 3.2 rear caliper also will fit 3.2 rotor . http://forums.pelicanparts.com/uploa...1323411553.jpg
http://forums.pelicanparts.com/uploa...1323411566.jpg
Tom '74 911 12-09-2011 07:53 AM
Read through this thread where eimkeith gives some rear flare location dimensions on page 3 - compare them to how yours fit w/the bumper and end up where you need to be. . .
http://forums.pelicanparts.com/porsche-911-technical-forum/298521-welding-flares-longhood-rsr-alignment-questions-3.html
boba 12-09-2011 09:25 AM
It is a good idea to do final fitting before welding with the wheels and tires that you will be using and at the final ride height.
don gilbert 12-09-2011 02:19 PM
everthing above, but a most critical measurement is from the inner wheel house out to the lip of the flare at the 12 o'clock position.
