-   -   stripped front targa pin need advice (http://forums.pelicanparts.com/porsche-911-technical-forum/644291-stripped-front-targa-pin-need-advice.html)
56 nomad 12-10-2011 11:07 AM
hi,
top on my 71 was replaced many years ago and while removing the pins for new skin one was loose, upon inspection looks like it was cross threaded and threads at the bottom of the pin are stripped. i cant seem to get behind to run a tap or replace the nut( cant tell if its bad either!)...any suggestions on a fix to get the new alignment pin to hold tight. copper wire, helicoil? anyone have a used pin?
regards, ben
56 nomad 12-10-2011 12:22 PM
problem solved copper wire super tight top is great... nice and tight as well , end of thread. ben
Joeaksa 12-11-2011 03:16 PM
If you need parts, Dan Petchel on this forum who restores these tops has all of that stuff...
