-   -   911SC is oxygen sensor system required to run properly? can I delete?????? (http://forums.pelicanparts.com/porsche-911-technical-forum/644400-911sc-oxygen-sensor-system-required-run-properly-can-i-delete.html)
marlinaness 12-11-2011 07:12 AM
I putting an 82 SC engine into a car that has the oxygen sensor removed. Do you need the oxygen sensor system? If I don't, do I just not connect it and what else do I do?
70 and 71 911s sure are easier.
thanks
Marlin
GaryR 12-11-2011 07:19 AM
Doesn't need it, but not sure what else needs to be done on the CIS system if you are keeping all the other stuff.
fred cook 12-11-2011 09:05 AM
O2 Sensor....
I have run my '80 SC both with and without the oxygen sensor plugged in. It did not seem to make any difference in the fuel mileage and the engine can be made to idle better with it unplugged. If nothing else, you could use the port for a wideband sensor to feed an air/fuel ratio gauge, etc. If you are in an area that requires emissions inspections, you probably will have to leave it in place.
john walker's workshop 12-11-2011 10:18 AM
you absolutely need the computer, O2 relay, frequency valve and the wire loom for it to run properly. as for the O2 sensor plugged or unplugged, try it both ways and see which one you like better. or change to a 78-79 fuel distributor and WUR.
marlinaness 12-11-2011 07:14 PM
John Walker,
thank you so much for the info. I don't have any of that now, so time to go find it.
best regards
Marlin
j911brick 12-11-2011 07:43 PM
I found that they run better when the system is hooked up and working, but if you delete it you may need a '78-'79 ignition distributor.
