Question 1970 T oil getting in air filter housing-why?
Does anyone know why you would get engine oil from the oil tank on a 70'-T up the vent hose and spill into the air cleaner housing?? It will do it when running and the nose of the car is elevated (not steep and the tank is not overfilled)
Old 12-11-2011, 08:44 PM
RETIRED
Joe Bob's Avatar
Do you have a restrictor in the oil return line? How do you describe 'overfilled'?
I keep mine below the 1/2 mark.
2012 ML350 3.0 Turbo Diesel
Old 12-11-2011, 09:07 PM
T77911S's Avatar
overfilled, even though you said no.
sometimes filled is just too much oil for the age/condition of the engine.
i NEVER fill mine to the top mark. usually to 1/2.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-12-2011, 05:08 AM
that, and blowby. the oil vapor collects in the filter housing. that's why there's a drain.
206 637 4071
Old 12-12-2011, 06:25 AM
The system only had 9qts at the time, front wheels were up on 6" blocks for some work on a fuel and the "restrictor" was in the vent line. I assume the restrictor is in there to limit this from occuring? engine has a few miles, belongs to my son. thank for the replies. 911 skooter
Old 12-12-2011, 10:44 AM
T77911S's Avatar
9qts, but did you check the oil level with the engine running, hot and level?
RACE CAR:: sold
Old 12-13-2011, 06:29 AM
