964 winsdscreen seal on 911
Hi guys!
Will a 964 window seal fit 911window frame and stock 911 windscreen(is it the same window,window frame and just the rubberpart that is different)?
Best regard Stefan
Old 12-18-2011, 03:50 AM
abisel's Avatar
This has been discussed before in extensive detail.
I believe the outcome is:
For pre-89 911 with the 10mm pinch-weld windshield flange, the 964 seal AND glass will fit but may be a little loose since the 964 seal and glass are designed for a pinch-weld flange of 15mm.
You cannont mix 911 glass with 964 seal or vise versa. The glass and seals have different dimensions between the 911 and the 964.
Old 12-18-2011, 04:25 AM
