Brando
No it didn't. I sourced that. It's a lightweight unit but I could use the one from the 911s engine if it was determined to have any fault which I doubt but what do I know till I can see better?
did you order it for a 911 or 930?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Brando
The clutch and flywheel both fit the 911 not 930. But once the flywheel is bolted on that crank case, it accepts the smaller unit. That crankcase is similar to the 2.7 and is the same as the 3.0 carrera. So to clarify, my clutch is the exact same as before with the same 915/61 and new flywheel made to fit the 74-77 2.7 engine family of crank. Maybe even earlier. But it only fits the early 6 bolt cranks which I believe to encompass the 72-77 cars including the turbo. The turbo used a 240mm flywheel and clutch but still has the 6 bolt crank. Am I wrong? I felt pretty confident that I have the right setup for the swap.
Brando
Well, didn't mess with that tonight, instead I adjusted the mixture and timing and made it run real nice. Sounds amazing I must say. Wish I could drive it
Brando
Well, the clutch was fine, I removed the engine, split the trans and engine to reveal a really nice brand new power clutch and pressure plate, no supprise there as I put it there. replaced the engine and adjusted the clutch, turns out thats all i had to do. Great, I could have been driving it for two weeks.
Turbo powa! 1977 911s. it's cool |
83 911 Production Cab #10
It only cost time and you probably shave some from your previous engine drop
![]() Bonne année
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Brando
I was reluctant to do an engine drop before the swap but it's really a no brainer. Hardest part is getting the bumper off and the axles undone.
I did mine with the bumper on as I had no height problem with a lift but it was a bit tight when you factor the angle to get the 915 shaft out of the tunnel...
Help a buddy doing his last week (930 with a 915) and with the bumper it was no problem at all even with all the extra parts on the 930,
