-   -   Question about Engine Light Retaining Screws (http://forums.pelicanparts.com/porsche-911-technical-forum/645658-question-about-engine-light-retaining-screws.html)
mercury26 12-18-2011 12:00 PM
Question about Engine Compartment Light Retaining Screws
Does anyone know the setup for the engine light retaining screws? I see the bar on the engine lid for holding the light. It looks like some type of body nut and screw would the setup for holding the light. I am looking in the parts catalog but do not see the part listed.
Also, a pic would be helpful
Thanks,
Chuck
mercury26 12-22-2011 06:13 PM
ANy help??? If someone has pics then that would help also. I am looking for the engine compartment light and how it attaches to the engine lid.
MConn 12-22-2011 06:50 PM
Here's the Pelican link -
Pelican Parts - Product Information: 911-631-315-01-OEM
Hope this helps.
KNS 12-22-2011 06:52 PM
I believe they are just two sheet metal screws and a couple of speed nuts holding it on to the little cross bar.
mercury26 12-22-2011 06:54 PM
Hope this helps.
Nope, I have the light already. I need to see how it is attached. The Porsche parts catalog does not have the screws or the nuts.
mercury26 12-22-2011 06:55 PM
I see, a pic would be super helpful.
MConn 12-22-2011 07:02 PM
The PET for my 87 model uses speed nut 999-507-028-02, and tapping screw N-014-093-3, the size is 4.2x13.
kodioneill 12-23-2011 06:43 AM
http://forums.pelicanparts.com/uploa...1324651380.jpg
http://forums.pelicanparts.com/uploa...1324651396.jpg
Dublinoh 12-23-2011 07:16 AM
Sorry for the quality but on my 1987 Carrera it uses a sheet metal screw
http://forums.pelicanparts.com/uploa...1324653328.jpg
81SCRosewood 12-23-2011 08:04 AM
Pic
From a 1981 SC. Hope this helps. SmileWavy
http://forums.pelicanparts.com/uploa...1324656251.jpg
Stan Gillis 12-25-2011 04:46 AM
I cannot understand how this light is mounted. Is there a support of some thing behind those mounting screws?
kodioneill 12-25-2011 06:29 AM
The light has two components a housing and a back.
Stan Gillis 12-25-2011 10:03 AM
How is the back attached to the rear engine lid?
BMWDavid 12-25-2011 10:13 AM
Sorry my camera is not at hand...but here is what my '89 3.2 has. The lamp assembly is held to two cross pieces that are spot welded to the rib.
On my car which is totally original the lamp housing is mounted with two sheet metal screws using two speed nuts.
Stan Gillis 12-25-2011 10:32 AM
I guess I won't be able to mount mine the same way, since I have a fiberglass deck lid.
