-   -   install case oil squirters: how (http://forums.pelicanparts.com/porsche-911-technical-forum/64566-install-case-oil-squirters-how.html)
Peterfrans 04-02-2002 09:36 AM
I am doing a rebuild on my 1970 911S. I have heard that in case of a upgrade to a 2.5 you should install the case oil squirters. Is there any point in doing so on a stock 2.2 S? Will tolerances in the P/C's which were based on higher temps be spoiled?
And if there is anypoint, what is involved in installing them.
rvanderpyl 04-02-2002 09:50 AM
Porsche started installing case squirters in the second year of 2.2 production so I guess they thought it was worther it. As far as doin git yourself I think you are best off getting a Porsche Machine shop to do the work as it involves driling holes in your case to hit an oil supply channel, and then installing and pegging the squirters.
TimT 04-02-2002 10:04 AM
What he said
I rebuillt my 2.0T into a 2.2S after I hand grenaded the motor on the track. Since I was goingthe S route I had the squirters installed whilst the case was being machined.
This isnt a DIY project, the hole for the squirter has to be drill at an specific angle to intercept the oil passages
http://www.pelicanparts.com/support/smileys/cut.gif
Wayne 962 05-12-2002 06:20 PM
Agreed. Send it to Walt at Competition Engineering - he's the expert in these types of modifications to the early mag cases...
-Wayne
