-   -   Do I need a valve guide seal or a valve job? (http://forums.pelicanparts.com/porsche-911-technical-forum/645747-do-i-need-valve-guide-seal-valve-job.html)
glennspiegler 12-18-2011 03:27 PM
Was so proud to be replacing fuel line myself. 88 911 220,000 miles. First the fuel line rubber hose ruptured by inj fuel rail. Removed the intake manifold to send orig fuel line to Mr. Hippe in Fla for recond. Pulled the injectors while there for reconditioning. The intake valve #4 which luckily was closed has this puddle of oil in the photo. All others appear dry, but when I opened valve to check the play, there was none, the oil drains out and u see the carbon on the lower valve seat. This wiped away easily, see last picture I think next is to remove exhaust valve cover and check for play. Could this be a bad stem/guide seal. I am not sure how to proceed. What the fate of my daily driver, or used to be. Thanks for such knowledgeable help. Glenn
#4 on right with a puddle of oil, #5 on lefthttp://forums.pelicanparts.com/uploa...1324249998.jpg
#4http://forums.pelicanparts.com/uploa...1324250182.jpg
#4http://forums.pelicanparts.com/uploa...1324250337.jpg
#4http://forums.pelicanparts.com/uploa...1324250544.jpg
#4 after opening valve, carbon on seathttp://forums.pelicanparts.com/uploa...1324250682.jpg
glennspiegler 12-18-2011 03:41 PM
#4 opened so oil ran out and some carbonhttp://forums.pelicanparts.com/uploa...1324251542.jpg
#4 open and wiped cleanhttp://forums.pelicanparts.com/uploa...1324251673.jpg
Flat6pac 12-18-2011 06:28 PM
I dont know how you got that much oil that high.
Bruce
glennspiegler 12-19-2011 03:53 AM
see below
glennspiegler 12-19-2011 03:55 AM
It does not burn oil. Approx one qt per 1500 miles. Thought it was coming from valve guides or a bad valve guide seal, is that not possible? Glenn
E Sully 12-19-2011 04:17 AM
Your oil consumption is good, but with 220,000 miles I would prepare for a rebuild. I would do a complete top and bottom end. After that it should be good for another 200,000.
glennspiegler 12-19-2011 05:13 AM
This is a bad time to give up the car. Would it hurt to run it until she burns oil and then do a top end. The rings were done at 70,000. Glenn
E Sully 12-19-2011 06:33 AM
I find it interesting the rings were done at 70,000. My '86 engine needed valve guides at that mileage, but the rings and cylinders still looked OK. I put in new rings since I had it apart for the guides anyway.
It is a high mileage engine. It is up to you, but keep in mind how the cost goes up if it jumps timing from worn timing chains or if it drops a valve. It must have worn valve seals and guides for that much oil to accumulate on the intake side.
It's your car and your choice. I would do it over the winter so that in the spring when the weather is nice I could enjoy driving it with out worries.
