Gears for a 915
I need a couple of good used gears for a 915.
I am looking for 4th gear 27:25 and a fifth gear 29:21 Does anyone know is a 925 Sporto 3rd gear which is 27:25 is identical to the 911 gear? Thanks |
RETIRED
I would suggest John Walker or Dave at TRE. They both post here.
Also a 'want to buy' ad in the classifieds.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bird. It's the word...
I've got some left over gear sets out of a 4 speed. I'm terrible with ratios, if you let me know the letters I'll have a lok and see.
John Forcier Current: 68L 2.0 Hotrod - build underway |
that 5th comes from a 912E trans. don't have one. do you want an overdrive 4th (0.92) or a 1.08?
gearhead
I might have the 5th as a used gear. I definitely have both ratios as new gears. Shoot me an email at gtgears@yahoo.com and I'll remember to check in the morning when I get to my workshop...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I am trying to convert a 915/02 to a 915/08 at least in terms of Ratio's
I have found a 27;25 but it is out of a 925/16 Sporto and I am not sure if this is OK. |
