-   -   confirming temp gauge readings (http://forums.pelicanparts.com/porsche-911-technical-forum/646397-confirming-temp-gauge-readings.html)
Reiver 12-21-2011 04:28 PM
gents, my 216 k mile car seems to be running a bit higher in temp than expected in the cooler temps...but not much.
210 cruising on a cool day at 72 mph flat terrain. 225 in stop/go on a cool day (60 degrees).
Could be the gauge no?
Called a local Phoenix Porsche shop and the owner said the oil in the filter will run about 10 degrees less than the indicated dash sender temp using an ir temp unit.
I am noting a 20 dgree temp dif...187 @ filter - 207 or so @ the dash gauge.
Has anyone heard this correlation before between the filter/gauge temps?
Joeaksa 12-21-2011 05:44 PM
Who are you using in Phoenix to get work done. There is one shop that I would not trust to work on a taxi-cab, not to mention a 911.
What year is your 911?
Joe
schumicat 12-21-2011 05:44 PM
if you want to know for sure, get a cheap mechanical temp gauge ($18 at pep boys) and drop the sender in the oil tank.
Reiver 12-21-2011 06:15 PM
Joe, it's an '83 SC.
Shumicat...I know the temp at the tank, was wondering about the delta between the tank itself and the reported sender temp from the motor.
DRACO A5OG 12-21-2011 11:36 PM
What kind of oil filter are you using.
When I tried the Napa Gold, due to it's high filtration it restricted oil flow and caused my temps to go up. It ay be just me but when I swapped back to Mahle, temps went to normal readings.
J
BTW, Use a IR reader and check the thermostat's two hard lines in the wheel well, that will give the most real time oil temps going in and out of the engine.
Joeaksa 12-22-2011 04:06 AM
Draco brings up a good point. If you can, put your hand on the oil lines running up front and make sure that both are the same temp.
I have seen thermostatic valves either not open or open partially and neither is good for your temps.
Reiver 12-22-2011 08:23 AM
Thanks,
German filter, the other therm and system works fine.
Just wanted to know if anyone had used the 10 degree temp diff between filter and sender as a check point or heard of that check before.
I'm suspecting a bad sender reading by 10 + degrees is why.
