Carrerax's Avatar
Bell Crank rod available?
I accidently broke off the bell crank rod on my 915 trans when I was taking it out. This is the threaded in rod that threads into the lower drivers side of the trans. It is about 3.5" long. I tried to find on in the catalog but cant. Does anyone know if they are avaialble? Thanks.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 12-29-2011, 02:39 PM
tobluforu's Avatar
Post a WTB in the classifieds as I'm sure someone has one laying around.
Old 12-30-2011, 04:19 AM
If you can give me the length so I can be sure I have more than one.
Bruce
Old 12-30-2011, 05:02 AM
kwikt 911's Avatar
Believe it or not .... I used a long collared bolt and retheaded the end to adapt to the 915 case. This has been 10 years ago and still working great.
Old 12-30-2011, 05:21 AM
Carrerax's Avatar
Thanks guys! I think I may have an extra one on an old 915 I forgot I had. It is about 30 min away though. Ill check it and let you know if I still need it. Another question, I have been reading about replacement clutch cables (for later 2 arm 915's) bieng too long and difficult/impossible to adjust. I am experiencing this problem. That is why I pulled the trans looking for a broken TOB arm or something. Anyway, all good inside. Have you had this problem with cables too long in the past?
Old 12-30-2011, 05:36 AM
