Dept store Quartermaster
lendaddy's Avatar
Post Proper gasket install?
Well, I'm going to button up the tranny tonight and was wondering how you guys "pretreat" the paper gasket for the inspection cover. Do you use any silicone or just wet the paper with a little gear oil first? Thanks
Old 07-25-2001, 11:30 AM
Early_S_Man's Avatar
Loctite 518 is the current preferred 'treatment' ... it is the good enough for the FAA as the replacement for Loctite 574 for use on piston aircraft engines!
Warren Hall
1973 911S Targa
Old 07-25-2001, 11:40 AM
Send a message via AIM to 82SC
Post
just a question...why was your tranny apart...
I am contemplating cracking mine open to replace some howling bearing...but I have heard that only pros should mess with the tranny...and I have heard DIY can handle it...
Just wondering if you were a successful DIY
Old 07-25-2001, 06:17 PM
