neatrix bushing question
Recieved my neatrix bushings for the rear spring plates (thanks pelican parts). Besides the 'detailed' (cough, cough) instructions, there was included a small tube of super glue. I'm guessing this would be applied to the same surface that is vulcanized to the metal. The question/s : how important is it to use the glue? (as I already have the bushings slimed up with silicon lube). Has anyone done this install with no glue at all? thanks, MAX http://www.pelicanparts.com/support/smileys/smash.gif
Put mine in about 3000 miles ago without the glue.No problems,I even had to pull the tortion bars again after about 1500 to go a little lower on my ride height.Car tracks great and is very quick and responsive in the corners. Hope this helps,Philip..
I'll second the "no glue" motion. Mine didn't even come with any glue. Just used plenty of silicon grease and have had no problems what so ever.
FWIW Chris Bunker 78 SC |
Thank-you gentlemen. I'll use the glue to fix some of the other stuff I break!! ....later,MAX
| All times are GMT -8. The time now is 08:35 AM. |
