-   -   Bosch K3 Vs Valeo Alternator (http://forums.pelicanparts.com/porsche-911-technical-forum/646883-bosch-k3-vs-valeo-alternator.html)
drgouk 12-24-2011 09:52 AM
Hi Folks,
I am looking at buying a new Alternator to suit my early 901 fan ring, Should I step up to the bosch K3 unit or will the cheaper valeo unit do the same job for less money? Your thoughts please.
Regards
drgouk 12-24-2011 12:46 PM
Valeo replacement ok then?
kidrock 12-24-2011 01:50 PM
You may seriously want to consider taking your old unit into an electrical shop that does rebuilds. There are many threads about this, and the general consensus is that our alternators are basic, nothing special, are simple to rebuild, and you will save a stupid amount of $$$$. Just sayin'
Joe Bob 12-24-2011 01:56 PM
Local rebuilds are better than a no name supplied by whomever. They may give you a life warranty but doing another r&r would suck.
Have it done right the first time.
JJ 911SC 12-24-2011 02:10 PM
[QUOTE=Joe
Have it done right the first time.[/QUOTE]
+1
Bought a cheap rebuild, VR went South, boiled the battery and spend a day to removed and put a new one VR in :rolleyes::(:rolleyes:
brads911sc 12-24-2011 05:29 PM
the new bosch versions arent german made and are no better than the Valeo. I got a new valeo (not reman) and it seems to be fine.
larrym 12-24-2011 08:22 PM
valeo is fine choice
i put a valeo in my 914-6 last summer - "one-wire" style internally regulated - no external regulator needed
wish i'd had it years ago
one caveat - the wiring diagram that came with it was WRONG - cost me a day's work to pull it backout & fix it after the eBay "TopSeller" in SoCal coughed up the correct diagram
Lorenfb 12-25-2011 08:47 AM
"I got a new valeo (not reman) and it seems to be fine."
Right, until it starts to overcharge!
"i put a valeo in my 914-6 last summer - "one-wire" style internally regulated - no external regulator needed wish i'd had it years ago"
Again, until when you have to change the regulator because of overcharging
and wish you still had an external regulator.
brads911sc 12-25-2011 10:07 AM
So then upgrade the regulator. there are several brands you can buy if I recall. the most expensive one i could find was less than $30. I dont recall the brand.
Lorenfb 12-25-2011 10:54 AM
"So then upgrade the regulator."
Doesn't solve the problem that internal regulators are less reliable than external
ones, i.e. the heat exposure of the internal, and are much easier to replace.
304065 12-25-2011 11:17 AM
Do those even fit? I would be concerned that any modern unit would be too thick and require the later fan ring. Maybe Valeo is making one with the same dimensions as the original 35A Bosch.
I am on record here as despising internal regualtors. There is no good electronic reason for them, and the heat and vibration of the location in a 911 is not good for them at all.
