-   -   Speedometer cable issue, why does this not fit 915? (http://forums.pelicanparts.com/porsche-911-technical-forum/647123-speedometer-cable-issue-why-does-not-fit-915-a.html)
jsoderbe 12-26-2011 11:13 AM
Hi,
I have a slight problem when installing my engine and trans into my 1973 T Targa. The speedometer cable does not fit into the 915 gearbox! The gearbox is said to be a 1974, the car is a 1973 and I believe my speedometer cable is from my 1972 911. The problem is that the gearbox has a square shaped speedometer drive, and the speedometer cable has just a flat slot in it.
Could anyone please tell me what part is wrong or what I have messed up? I am somewhat tired today....
Thabks,
Johan
jsoderbe 12-30-2011 02:02 PM
Anyone?
Please let me know.
Thanks,
Johan
Porboynz 12-30-2011 11:36 PM
Johan, I can confirm that the 1972 cable is designed for a flat blade shape drive as per the following picture of the speedo drive from my 1972 915 gearbox. If your 74 gearbox has a square drive then you have 2 choices, replace the cable with a later 74 version or replace the drive gear. The cable change sounds easier, maybe just needs a change to the inner if the outer large threaded connector is the same for the 72 and 74.
http://forums.pelicanparts.com/uploa...1325316763.jpg
Maybe its possible to turn the blade into a square with a die grinder, but thats a one way process and I bet its hardened steel.
jsoderbe 12-31-2011 01:18 AM
Thanks, I apprecitae your input! What made me confused was that pelican sells one for 65-73....
Now I know that thy could differ. Now I just have to rder the right one. Great input!
Thanks, Johan
john walker's workshop 12-31-2011 07:26 AM
never seen a square drive off the trans. maybe you have a section of the old cable still on the trans.
