-   -   Question(s) on replacing oil line (http://forums.pelicanparts.com/porsche-911-technical-forum/647322-question-s-replacing-oil-line.html)
markmalin 12-27-2011 10:16 AM
Hi everyone.
I picked up an oil line section, the one on the right side of the motor over the right cam chain cover (sorry if the terminology is wrong). I'll post a picture below. I have a couple questions about replacing it - I don't have a service manual yet.
- Anything special for the procedure, or can I just swap it out? For example, do I need to drain the oil or anything?
- what are the torque specs for the bolts?
- then...should there be crush rings on the one end?
Thanks, guys!
Humbly,
Mark.http://forums.pelicanparts.com/uploa...1325009710.jpg
CCM911 12-27-2011 12:31 PM
I did mine without draining the oil. If I remember correctly, I had to be really patient, as there is not much room in there to get a decent turn on the wrench. But without the AC Bracket, your's should be no problem at all.
Have fun!
schumicat 12-27-2011 12:47 PM
you don't need to drain oil. there are crush rings (2) on the valve cover side of the line, which uses a banjo bolt. There's little room for torque wrench in there. I just used my judgment in not overtightening.
markmalin 12-27-2011 12:56 PM
Thanks guys. Looks like I'll need to pick up the crush rings at the local dealer :( Was hoping to do the job this morning, but not to worry.
Targa Time 12-28-2011 03:20 AM
Make sure to support the connection at the fan where the oil pressure sender connects with a wrench. Too much torque can crack the case. Then you have a big problem. Tighten it snug, start engine. If it leaks tighten slightly more.
