-   -   spindle o ring question (http://forums.pelicanparts.com/porsche-911-technical-forum/647532-spindle-o-ring-question.html)
ncseahawk 12-28-2011 09:53 AM
Ok...so I am replacing wheel bearings (front) and I have the 0 rings associated with the front spindles . question is if I didn't have any O rings on there when I removed the front hubs....
where do the new O rings go ? Do I need them at all .?
stlrj 12-28-2011 10:22 AM
Are you calling seals "O" rings?
ncseahawk 12-28-2011 11:26 AM
I am however this is what the wizard showed when I purchased the wheel bearings from our host
m1franck 12-28-2011 01:25 PM
The O ring goes behind the inner wheel seal collar and the base of the spindle. If you are not removing that collar, then don't worry about using the O rings
http://forums.pelicanparts.com/uploa...1325111488.jpg
ncseahawk 12-28-2011 02:21 PM
Got it. Thanks for the good news
