-   -   Can the vent in the middle of a dash be removed without taking off the whole dash? (http://forums.pelicanparts.com/porsche-911-technical-forum/64776-can-vent-middle-dash-removed-without-taking-off-whole-dash.html)
Russ 04-04-2002 11:09 AM
I have a later dash on my '72 with a vent in the middle. The vents apparently dont move from side to side, and when I tried I broke one off. I can get it with tweezers and glue it back on but would prefer to remove the whole thing and do it right. Do I have to remove the dash? I dont want to just pull at it cause I allready broke it once.
Russ
rlane 04-04-2002 12:05 PM
I think you can but to undo all 4 tabs is difficult and you would be better to come at it from the trunk. I have this on my own "To Do" list. I also think you might have trouble resuring the tabs with the new piece in there.
Do a search on "dash vent" here and you will find several threads with much more erudite response.
cary 04-04-2002 12:21 PM
Pull out the clock. Gives you all kinds of room to wiggle and work.
Search should get what you need.
