will a 2.0 carb airbox fit on a longer stroke 2.4 with carbs?
Will the stock carb airbox from a 2.0 fit on the longer stroke 2.4, or are the cylinders longer thus putting the heads further apart? Has any one checked this?
Thanks, Russ
Old 04-04-2002, 11:05 AM
jluetjen's Avatar
The heads are spaced no further apart in a 2.4 then they are in a 2.0 -- at least not because of the stroke change. When Porsche increased the stroke, they shortened the conn-rods to keep the deck height the same. The ring sealing system between the heads and the cylinder was changed, but I doubt you will see it in the spacing of the intakes.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-04-2002, 03:05 PM
I have a 2.0L and a 2.2L sitting in my garage. I measured the spacing across the intakes last night and as John said they are exectly the same.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 04-05-2002, 04:42 AM
