-   -   Is there a way to test the rear window defogger relay? (http://forums.pelicanparts.com/porsche-911-technical-forum/648655-there-way-test-rear-window-defogger-relay.html)
Tidybuoy 01-03-2012 12:29 PM
My rear window defogger does not work. It's possible that the window itself is the problem or it might be the relay or something else.
When I saw the $193 price tag on a new relay....well, I figure I should test it to see if it works before I spend the $$$.
Any advice would be great.
schumicat 01-03-2012 12:50 PM
yes, using some jumper wires if you know how the read the diagram on the side of the relay. you can get them used for $25 or so on ebay. you can also just listen/feel for the click at the relay while someone pulls the defrost knob.
Tidybuoy 01-03-2012 01:03 PM
Thanks! My friend is an elictrical guru so I will get him to help me read the diagram.
