Carrera and Stone Guard removal
All,
I need to give the car a very thorough exterior detail over the next couple of days. The stone guards came off though left some tacky residue. Id also like to remove my Carrera badge on the rear deck but assume that will leave residue also.
1) How to safely remove the Carrera badge? Ive heard using dental floss to saw through it works, any better suggestions?
2) How to I get the glue off without damaging the paint?
Thanks!
Thanks,
Chris
1980 Targa, 3.2 upgrade
Old 01-05-2012, 06:00 PM
Text me.828-230-0788
Joe Bob's Avatar
Goof Off...
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 01-05-2012, 07:46 PM
Rescuer of old cars
Arne2's Avatar
3M Adhesive Remover
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-05-2012, 08:02 PM
I removed many badges before, it's a two step process:
1. Remove badge by using thin plastic rope / thread (dental floss is not strong enough) with "sawing" motion. Do not pull the badge as this may damage surface.
2. Remove glue residue by dab it with kerosene or gasoline (a little amount is safe for paint) then scrape it with plastic scrapper (or credit card).
Lastly polish the paint with compound and wax it off.
Old 01-05-2012, 11:36 PM
cdrik915's Avatar
The better way i found to remove glue residues is White-spirit.
No problem with paint if done without sun shining on and washed after a few minutes.
Also for asphalt residues : apply it and appreciate how it works : the asphalt leaks.
I use that way of doing since many years.
LIGHTER = FASTER !!!
Old 01-06-2012, 01:06 AM
cdrik915's Avatar
Comparing to dedicated products , more expensive , i find "White-spirit" more efficient.
(Sorry , twice)
Old 01-06-2012, 01:08 AM
911oclock's Avatar
Eucalyptus oil will remove the adhesive easily and is gentle on the paint.
Old 01-06-2012, 05:22 AM
mystro's Avatar
Wax will take off residue from decals. I keep a container of cheap wax around like Nu polish just for this purpose.
Old 01-06-2012, 06:55 AM
Flat Six
Flat Six's Avatar
Monofilament fishing line is ideal for this purpose -- thin, long, and sturdy.
Also, heat up the emblem a little w/electric heat gun (on low) or hair dryer (on high) to help soften the adhesive and the Carrera emblem. Don't go so hot you blister the paint, just warm enough and the emblem will come off easily and leave less residue, too.
1985 Carrera 3.2
2013 Audi Q5 2.0T / 2005 BMW 325ci
Gone but missed: 2007 Audi A4 Avant Quattro / 1990 944S2 Cab / 1984 944 / 1990 Audi 80 Quattro / 1987 Audi 4000 Quattro / 1987 BMW 325is
Old 01-06-2012, 09:33 AM
Thanks all for the advice!
Chris
Thanks,
Chris
Old 01-06-2012, 10:38 AM
French Import
zippy_gg's Avatar
Is your Carrera badge in good shape? If so can I have it? My cab doesn't have it but can see its outline on the engine lid. You can PM me. Thx!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-06-2012, 11:32 AM
